Seat Belt Buzzer
pal1
Hi
Anyone know if there is a fuse or relay that will stop the seat belt warning bleeper.
mike
Hi Dan,
this topic was covered in some depth on the forum round about 6 months ago. Worth a search as it was ( from memory ) a fairly complex solution.
Quite right Chris, and i think this was posted by Dan before or he replied on it
Del
just cut the metal bit off the seat belt and insert into the buckle. The beeper will never know you've cut the belt.
Hi
I did try for a solution months back, lots came up with the, 'turn key...push computer...clip in seat belt' method. That doesn't work on mine. There must be a rely that works it.
mike
Why do you want to disable it?
We have been down this road, and if I remember rightly, the answer to anchs question from Mike,or is it Dan,caused some alarm from other members.
Del
Put the belt on, simples, no buzzer ;)
Which was i think the answer I gave last time
Kingo :thumbsup:
