The cover of the towbar socket broke and it´s a stationary part. So I´m going to buy a new original socket ( PZ417-99560-05 ) ( look at page 3: http://www.toyota-te...Toyota%207P.pdf ).
Could someone tell me how to connect wires to socket? (look at page 31: http://www.toyota-te...001%20565-1.pdf )
Edit: I have circuit diagram. I´d like to know how to fasten the wires. Tin?
Big HI to you,Atte,and welcome to a great club :thumbsup:
I assume you are asking how to treat the wire ends before connecting them to the socket,tinnings good.
I have seen many ways of treating the ends that seem to work after stripping about !/4 inch (6 to 7mm) of the insulation back, that work
Like just pushing in the bared core or folding the strands back over the insulation and pushing that in.
I suppose time is a consideration but as you are doing it yourself soldering is a good method.
One thing I always did was to seal inside,after connecting,with silicon sealent as a lot of water gets thrown up against it causing corrosion
Del
