I keep getting into my new Aygo only to find that the air control slider has been changed from fresh air to recirculating. I have been blaming my wife but the other day I noticed as I closed my door, the slider moved about 2 cm towards the left presumably due to the positive pressure at the point of door closure. So after getting in and out of the car a few times the slider control moves completely over to the recirculating section. Its only after driving for a little while that the windows start to steam up that you are reminded of this slight design defect and you have to manually slide the control back to the fresh air section.
I have noticed that the slider moves mid way between fresh and recirculating
Same. May have shouted at a small child. :(
