Yaris 2008 Alloy Fitment Please?
Paul08
eBayISAPI.dll.htm
I have a 3 door Yaris 2008 and have recently seen some alloy wheels but i am not sure if they will fit:
OZ racing superturismos, 4x100, Rim Diameter:16, Width: 7J, Offset:42.
I would be great full if someone could let me know if these alloys would fit and if not then what is the correct alloy fitment for this vehicle. Thankyou
eBayISAPI.dll.htm
Hi mate, on our 2008 Yaris SR the standard fitting Toyota Motorsport wheels (made by Ronal) on the inside they are stamped 7x16H2ET45.
Pete.
Don't forget that you also need to check the "bore" which is the size of the hole in the middle, as this sits on the hub sharing the load.
Looking on the internet, it suggests the Yaris fitment is:
4x100 PCD.
ET (offset) 35-45
Bore 54.1mm
If the bore is too big, you can get "rings" to make it smaller from aftermarket alloy shops, but I've never gone down that route myself....
