2004 D4D Wont Start After Squeaking Noise
Geralt
Hi All,
I have 04 d4d t3x 116bhp. This morning when i started the car i heard troubling squeking noise - like some sort of belt slipping- but she has done that few times and then it always went away. so I drove off to work (80 miles) and the noise was comming and going for about half of the journey . When i nearly arrived (i was about 2 miles off my workplace) my dashboard lit up like christmas tree. Oil, coolant and Battery indicators came on at the same time and then after a while also the ABS indicator lit up - although it was coming and going. When i arrived , I switched off the car and tried to switch it back on but it wasnt starting - like the Battery was dead. So i have tried to disconnect the Battery and reconnect to reset it but no avail. Also the battery indicator (on the battery itself) show as green.
Any ideas?
TIA
change the belt + check tension roller.
Hi Igor.
do you mean alternator belt?
Hi Igor.
sure i dothe belts is responsible for good voltage feeding all el systemcheers
Thanks Igor, much appreciated
Will have to get mechanic to do it as I do not know enough to do it myslef. Will update when I'll know something
Belt or alternator failure
  • 2 months later...
Well i was ment to report back , but completely forgot
I guess better late then never....
Anyways it came out that coils on the alternator have fried .
Mechanic told me it can be regenerated but the coils will be 150 euro , or he can get 2nd hand alternator and fit it for the same price. So I went with the latter option. All works fine now
BTW Toyota has placed alternator in the most awkward place possible
