Replacement Locking Wheel Nuts
boolean
I have just bought a Yaris mk 1 05 plate privately which so far is proving to be very good. The only issue is that I can't find the special nut which will unlock the nuts on the alloy wheels. When I bought the car I saw the box with the nuts in but didn't open it to check, and it contains just four normal nuts rather than the one needed. Doh. The previous owner has said that as far as he is aware the set should be complete.
How would I get hold of a replacement? The box has a barcode on it so presumably I could take it to a dealer, but are there cheaper alternatives that I could use?
Thanks for any advice in advance.
