Syptoms Of The Mass Airflow Meter Going Faulty?
Predazord
Hi everyone,
Could you give me some idea what would be the syptoms of the Mass airflow meter going faulty?
The car is a 2004 Avensis Est 2.0 VVTI
rpm erratic or high petrol consumption
regards
massive flat spots as well
I have massive flat spots that need kind of reving through, then it picks up quickly....rpm seems to blip on idle, but not hugely. MPG isnt bad 32 to 33 mpg consistently....
Seems weather dependant......
Sound like likely symptoms?
also check with condition of throttle itself -- may be the flap does not cover a hole firmly -- normally it is subject to be serviced/washed.do not forget the sparks might also influence on rpm.regrds
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
