98 Camry
sprattd8
I have a 98 camry 2.2L 4 cyl. it has an oil leak on the corner of the timing cover between the engine block and the cover (firewall side). I have removed all of the bolts from the cover but i can,t clear it from the oil pan. do i need to remove the oil pan first or am i missing something?
i can wiggle it but i cant get it away from the oil pan at the bottom. :disgust:
Welcome to the TOC Derek. Try putting your question on the Camry forum for best results from fellow owners of your model. Good luck.
