Hi , I have a 54 plate verso 4D4 T3 and seem to have the EGR symptons so i want to remove and clean it. I cant find anywhere which shows how to do this showing the location of the valve. Can someone point me in the right direction.
thanks
I cleaned mine out last year using this tutorial. The engine in the guide is a D-Cat, but EGR exactly the same as my 2.2 D4D.
http://www.toyotaownersclub.com/forums/index.php?showtopic=106241
They did change the EGR valve at some point, so yours may not be the same as the guide. I think the older model engines have the valve on the right hand side, but I am sure someone will be along soon to confirm.
P.S. Buy a couple of cans of carb cleaner from your local motor factors and be prepared to get dirty!
