Glanza V 4E Fte Ep91
glanza2011
hi all
this is my first message writting to all u starlet boys out there respect to all
got my self a glanza v 4e fte
Quite nice cars these are ay
right had a engine rebuild as crank was effed change every bearing, bolts. gaskets seals that were in the bottom end and got my self a neww crank to.
all put together nicely and in the vehicle now
started it after i gace the crank a lot of turning via ratchet to check compression and timming and all were fine (compression was great)
Started it it started after about 6 ignition cranks and pured very nice
at present my oil warning lamp indicator is staying on on the dash and it went out when i ran the engine the first time last night
Slightly idling funny now as well idles low and then normal sometimes not sure if oil pressure or oil sensor faulty or playing around are there any common problems that I dont no about
post-123192-0-55529900-1340827412_thumb.
post-123192-0-63783900-1340827983_thumb.
post-123192-0-79747300-1340828010_thumb.
post-123192-0-45403800-1340828065_thumb.
Hello Tony, top looking motor, welcome in to the TOC
welcome to the club Tony.
