Power Loss
Karry
3 litre M reg toyota surf losing power under throttle. Engine management light shows. Lift throttle and coast - light goes out, power returns. Have been told it is code 14 (or R14) error , which is control valve (or solenoid valve) for fuel pump.
Does anyone know where I can get one please? Or if there is an alternative that will work just as well. Surrey area. Thanks
hi
you can ask Mr Parts King ---- an official original toyota spares trader on the forum.
He offers spares at discount for TOC members.
regards / Igor
Change main fuel filter before embarking on a costly fuel pump. Fuel starvation brings up code 14. I run on bio & have had this problem a few times.
  • 11 years later...
So I got a problem with my 1996 2.4l ssr-x rzn185 4x4. When it shifts to second it immediately loses power. Still runs and still gains speed but won’t go over 2k rpm when I have the pedal to the floor like 90 percent of the time it works like it should about 10 percent of the time. I checked the solenoids and ecu they are working like they should. Any body got any ideas what else it could be. Thanks for the help.
