hi only just joined has anybody replace a bulb in the dashboard panei
i,ve got a 1.4 diesel and the warm plug light doesn,t light up on ignition
took it to my local garage who checked the wiring said i could just be the bulb
Thanks in anticipation
There's no bulb to replace: the entire intrument cluster uses LEDs for illumination ans warning lights.
So if it's not orking they'll probebly need to replace the entire cluster, as opening it up is not a small feat
an certainly not something a regular car dealer can and/or will do...
