Help!
crazzi_chris
pls anybody....
got given an '87 Celica 2.0 GT
after disconecting the Battery and fixing the alarm
it now fails to start although previous to this it was starting perfectly
is there some kind of immobiliser or something thats stopping it?
if so how do i sort it
any help will be appriciated
thanks in advance
Does the engine turn over but not start?? Or does nothing happen at all when you turn the key? Any idea what make the alarm is? Any halfway decent alarm will have some form of immobiliser, you may need to identify which circuit or circuits it operates on. If the motor wont even crank then its the starter thats immobilised.
it turns over perfectly just fails to fire
its a toyota security system of some sort
believe it was factory fitted
its as if its killed the fuel or something
