Total Indicator Fail After Using Trailer!
Lazzlo73
Hello.
New member with new problem.
I towed a trailer and after a couple of hours the indicators were totally dead.
I checked fuses n all good there. Hazard also dead n when central lock is used also no indicators...soo all dead.
I suspect the relay but that is hard to get to.
Just wanted to see if anyone has suggestions/experiances about what it could be before I take the IP down :-o
Grateful for all tips.
//Lars
BTW...Avensis 2005 2.2D-CAT Stationwagon...
  • 10 months later...
Hi lazo I've got the same problem how did you fix this problem ?
Hi there have you fixed the problem ? If not look in the engine bay and find the fuse box that is near the passenger Wing ! The thin long one .open it and find fuse that says "hazard" it should be a 10a fuse just check that ! Hopefully that's what ya problem should be
