Auris Rattle
AURISTR01
Posting to say I have experienced 2 annoying rattles...
Easy Fix for those of you who may still have it.
Inside centre console sounds like a squeak/creak
Fix: under the front passenger footwell below the dash is a plastic cover clip it back on.
Rattle at idle from outside of the car at idle or normal driving.
Fix: Exhaust heat sheild under rear muffler or centre of the car difficult to get to without putting the car on a ramp I just pulled it off with some effort. As I dont park on grass chances of the car catching fire are slim, though I know its better to have it as it obviously serves a purpose.
Hope this will help some of you out if you still havent got around to the rattle.
The heat sheild is there to stop the heat being transfered upwards to the floor panel or any cables , petrol /brake pipes above the exhaust pipe or silecer box.
