1998 2.0 Td Fault Code 9
damien76
hi, i have a 1998 avensis 2.0 td that wont start. the mil is on so i did the paperclip test and retreived fault code 9. cant find a list to tell me what this means. can anyone tell me what this code definition is and what exactly it means or where i could find this info. thanks for reading guys.
1 Normal Condition
2 Air Flow Meter signal
MANIFOLD AND/OR AIRFLOW METER SENSOR circuit
- AIRFLOW METER/circuit
- MANIFOLD PRESSURE SENSOR/circuit
3 Ignition signal
-NO "IGF" SIGNAL to ECM
-IGNITER/IGNITER CIRCUIT
-IGNITER AND IGNITION COIL/circuit
4 Engine Coolant Temperature Sensor signal
- OPEN or SHORT IN WATER TEMP. SENSOR
- WATER TEMPERATURE SENSOR circuit
5 Oxygen Sensor OXYGEN SENSOR SIGNAL/OXYGEN SENSOR HEATER Signal
OPEN OR SHORT IN OXYGEN SENSOR OR OXYGEN SENSOR Signal
6 RPM signal (Crank Angle Pulse) RPM Signal
- NO SIGNAL to ECU FROM DISTRIBUTOR ("Ne" or "G") AFTER ENGINE HAS BEEN CRANKED
- DISTRIBUTOR/circuit
- STARTERSIGNAL circuit
- IGNITER/IGNITER circuit
7 Throttle Position Sensor Signal
- OPEN or SHORT Signal
- TPS SENSOR
- TPS Signal/circuit
8 Intake Air Temperature Sensor Signal
- Open or short INTAKE AIR TEMP. SIGNAL
- INTAKE AIR TEMPERATURE circuit
- INTAKE AIR TEMPERATURE SENSOR
9 Vehicle Speed Sensor Signal
-NO SPD. SIGNAL FOR SEVERLA SECONDS WHILE VEHICLE IS OPERATED UNDER HEAVY LOAD
TPS/MAP/AIR FLOW INPUTS)
- SPEED SENSOR/circuit
10 Starter signal
11 Switch signal LOSS OF POWER SUPPLY TO ECM
-IGNITION SWITCH/circuit
-MAIN RELAY/circuit
12 Knock Control Sensor signal
STARTER SIGNAL
- NO "STA" SIGNAL TO ECM UNTIL ENGINE SPEED EXCEEDS 800 RPM
- IGNITION SWITCH/circuit
12 RPM signal (G22 for –FSE)
- NO SIGNAL TO ECM FROM DISTRIBUTOR ("Ne" OR "G") AFTER ENGINE HAS BEEN CRANKED
-IGNITER/IGNITER circuit
12 Crankshaft position (CKP) sensor - circuit malfunction (3C-TE)
13 Knock Control CPU (ECM)
13 RPM signal (NE for –FSE)
SAME AS above but after ENGINE has RUN AT 1,000 - 1,500 RPM
-DISTRIBUTOR/DISTRIBUTOR circuit
13 Fuel injection pump position sensor – circuit malfunction (3C-TE)
14 Turbocharger Pressure
14 Ignition signal
- No "IG" or "IGF" ignition signal to ECM from ignitior several times in succession (IGT1, IGT4, IGF for –
FSE)
- NO "IGF" SIGNAL TO ECM
- IGNITER AND IGNITION COIL/circuit
14 (2C-TE) Timing control system malfunction
15 Ignition System (IGT2, IGT3, IGF for –FSE)
15 (1CD-FTV) Throttle motor - circuit malfunction
15 Throttle control circuit - malfunction
16 Faulity in transmission/transaxle ECM (Transmission control signal)
17 Engine control module (ECM) -malfunction
18 Fuel quantity adjuster -malfunction MI
19 Acceleration Pedal Position (AAP) Sensor/Switch circuit malfunction (VC, VPA, VPA2, E2 – for
FSE, 3C-TE)
21 Oxygen Sensor
OXYGEN SENSOR SIGNAL/OXYGEN SENSOR HEATER SIGNAL
- OPEN or SHORT IN OXYGEN SENSOR OR OXYGEN SENSOR SIGNAL и еще десяток причин...
22 Engine Coolant Temperature Sensor signal
- OPEN OR SHORT IN WATER TEMP. SENSOR SIGNAL
23 Intake Air Temperature Sensor signal
- OPEN OR SHORT IN INTAKE AIR TEMP. SIGNAL
24 Intake Air Temperature Sensor signal
25 Air-Fuel Ratio Lean
- LEAN SIGNAL SENT TO ECU FROM O2 SENSOR
- INJECTOR FAULT(S)
- FUEL PRESSURE
- OXYGEN SENSOR
- AIRFLOW METER OR MAP SENSOR
- IGNITION
26 Air-Fuel Ratio Rich
- SAME AS ABOVE
- COLD START INJECTOR
27 Sub Oxygen Sensor signal
- SUB OXYGEN SENSOR/HEATER circuit
28 No. 2 Oxygen Sensor signal
No.2 OXYGEN SENSOR/OXYGEN SENSOR HEATER
- SAME AS CODE 21
29 No. 2 Oxygen Sensor signal
31 Air Flow Meter signal or Vacuum Sensor signal circuit
- AIRFLOW METER/CIRCUIT
- MANIFOLD PRESSURE SENSOR (MAP) circuit
32 Air Flow Meter signal (VANE-TYPE)
32 (Diesel) Malfunction Resistance Signal
32 (2C-TE) Module coding plug - malfunction
32 (1CD-FTV) Injector - malfunction
33 IAC Valve
- OPEN OR SHORT IN IDLE AIR CONTROL VALVE Signal CIRCUIT or IDLE AIR CONTROL VALVE or ECM
33 Intake manifold air control solenoid –malfunction (3C-TE)
34 Turbocharger Pressure signal
- ABNORMAL TURBOCHARGER PRESSURE
- TURBO CHARGER
- AIRFLOW METER/MANIFOLD/TURBOCHARGER PRESSURE Signal
- INTERCOOLER SYSTEM
35 Turbocharger Pressure Sensor
- TURBOCHARGER PRESSURE SENSOR (Gas.)
35 Manifold Absolute Pressure Sensor (Diesel, 3C-TE)
35 HAC Sensor signal
-OPEN CIRCUIT IN HIGH ALTITUDE COMPENSATOR Signal
36 *
36 Sensor Combustion Pressure (Toyota Part No. 89468-20020)...
39 (Avensis) Fuel temperature sensor - circuit
39 VVT-i Valve (p1656,p1345,p1349, OCV for -FSE)
39 Fuel temperature sensor - circuit malfunction (3C-TE)
41 Throttle Position Sensor signal
- OPEN OR SHORT IN TPS Signal
- TPS Sensor
42 Vehicle Speed Sensor signal
- NO SPD. Signal for SEVERLA SECONDS WHILE VEHICLE IS OPERATED UNDER HEAVY LOAD
(TPS/MAP/AIR FLOW INPUTS)
- SPEED Signal circuit MI
43 Starter signal
- NO "STA" Signal TO ECU until ENGINE SPEED exceeds 800 RPM
45 EGR System malfunction
- VSV EGR
- Temperature Sensor
47 Sub-Throttle Position Sensor
- Open or short circuit in Sub-Throttle position sensor signal
47 Throttle position (TP) sensor
48 Vacuum Switching Circuit of Air Sw. Valve or Air Pump (EAP) Malfunction
49 for D-4 System SFP (PR, VC, E2 for -FSE)
51 Switch signal
SWITCH Signal IDL (tps) CONTACTS OFF, NEUTRAL START SWITCH OFF, A/C SWITCH "ON" Signal TO ECM
WITH DIAGNOSTIC CHECK CONNECTOR SHORTED
- A/C SWITCH/circuit
- A/C AMPLIFIER
- TPS/CIRCUIT
- NEUTRAL START SWITCH/circuit
52 Knock Sensor signal
- OPEN OR SHORT IN KNOCK SENSOR Signal
- KNOCK SENSOR/circuit
53 Knock Control signal in ECM FAULTY or Engine control module (ECM) knock control – defective
(P1605)
54 Inter-cooler ECM signal
Intercooler coolant circulation capacity diminished (fail-safe operation: ignition timing program retarded by
2 degr.)
55 Knock Sensor signal
Open or short circuit in knock sensor signal (Chaser TRD with 2JZ-GTE)
56 Cooling Fan Pressure Sw.
58 SCVP, E2, SCV+, SCV (for –FSE)
59 VVT-i Valve - for FSE)
71 EGR System
EGR VALVE MALFUNCTION
- EXHAUST GAS TEMPEATURE BELOW SPEC. FOR EGR CONTROL
- EGR SYSTEM
- EGR GAS TEMPERATURE SENSOR circuit
72 Fuel Cut Solenoid signal
IGF SIGNAL IS DETECTED FOR 4 CONSECUTIVE IGNITIONS
72 A/C System (A/C Relay Open)
78 (Avensis) Fuel circuit - malfunction
78, 79 Fuel Pump Control signal (S+, E1 for FSE) (P1235
- Fuel Pump Control signal, P1200- Fuel Pump Relay/ECU Malfunction ?)
- Open or Short circuit in fuel Pump Control circuit or Fuel Pump Electronic Control Unit (ECU)
79 D-4
81 TCM Communication
- Open in ECT1 circuit between ECM & Transmission Control Module (TCM) for at Least 2 seconds
83 TCM Communication
- Open in ESA1 circuit between ECM & Transmission Control Module (TCM) for 1/2 second after engine
idles at least 1/2 second
84 TCM Communication
- Open in ESA2 circuit between ECM & Transmission Control Module (TCM) for 1/2 second after engine
85 TCM Communication
- Open in ESA3 circuit between ECM & Transmission Control Module (TCM) for 1/2 second after engine
89 (P1125, 1126, 1127, 1128) read a pulse ETCS-SNOW (Chaser TRD with 2JZ-GTE)
92 D-4 (p1210)
96 (p1600) Engine control module (ECM) -supply
97 D-4 (p1215) EDU Malfunction
97 (Avensis) Injector control module – circuit malfunction
98 D-4
99 (B2799) there is a trouble with immobilizer (for the OBDII-equiped Vechicle)
* for Lexus a 90-94. Abbrevations (Toyota and Lexus a 1990-2000), CPS - Crank Position Sensor...
Does your speedo work or have you had a problem with it??
A code 9 would not stop the engine from starting
thanks phil01. thats great to have those codes even if it isnt my problem this time. didnt notice any problems with the speedo. when car is cranking it does attempt to start but can also go from normal cranking to a faster speed of cranking. thanks again for the codes.
