Rav 4.1 Fuel Leak !
Worlds End Stu
Why do problems all appear together? If they happen in 3's I should expect something else to go wrong next week :-)
I needed to fill up with fuel yesterday, i'd only put about £20 in when I noticed petrol ****** onto the floor!
Once I stopped fuelling the leaking stopped with just a few extra drips coming off.
Checked this morning and there's been no further evidence of fuel leaking out.
I have a sneaking suspicion it was coming out whatever hose or pipe it is that connects the fuel filler to the actual tank.
Is there a known issue with this component decaying?
Any top tips on the best way to check this out?
It will almost certainly be a rotten metal pipe, the filler neck from tank opening to the tank itself. I think you might have to drop the tank down a tad to get the neck off the tank, not cheap though, about £120 ish. Apart from the obvious hazard and waste of expensive fuel, it would not pass an MOT like that so needs sorting out properly
Kingo :thumbsup:
