T180 Judder
Michelin
I have noticed recently that my T180 has started to judder when you are on an open road doing a steady speed.Say I've got it at 60mph and keeping it there the engine judders for a few seconds and then goes ok and then does it again on and off.If i accelarate its fine its only when cruising at a steady speed.Around town its fine it only happens on an open road at a steady cruising speed.Anyone got any ideas what this could be before I get ripped off somewhere
Partially blocked fuel filter or air therein...?
Techo Kev
Have a check of the filter that Kev has said! Clean the air filter/replace and check to see if the the EGR valve neeeds a a clean. Have you cleaned the MAF? its where the air comes into the air filter? Some CRC spray or electrical contact cleaner wi;; do the tricfk! I'd bang some Shell V-Power in the motor as a clean up also!....
