hi everyone have a carina e 1994 2.0 i trying to fix rear suspension but trying to install new trailing arms could not get bolt out of back of wheel hub carrier , bolt rusted solid to center of bushing so lost the plot and took the grinder out have chopped the bolt out and removed the bush does anyone know where to get replacement bush as dealer no use trying to sell me full hub carrier at £180.00 have
Toyota have never supplied the bushes seperatly, you can only get them in the hub, so your dealer is correct on that
Your only other alternative is to find somebody like Polybush who may be able to help
Kingo :thumbsup:
THANKS FOR PUTTING ME IN THE RIGHT DIRECTION MABYE SHOULD NOT SO HARD ON THE DEALER LAD .WILL TRY POLYBUSH TA ONCE AGAIN FOR THE REPLY
found a bush on rockauto web site carina e trailing arm suspension bush with royal mail postage so it must be from uk postage and VAT £12 thats a bit better as cheapest polybush -powerflex was over £60 will let everyone know if it fits
  • 4 months later...
Did you succeed?
Is the trailing arm the same as is described as the transverse link or control arm?
I'm having a problem sourcing a replacement control arm - adjustable link - squeaking a whole lot.
  • 4 weeks later...
