Headlight Bulbs
wedryjoel
A stupid question probably' but can someone pls tell me how you get the headlight bulbs out of the Celica gen5, As one of my main beams is blown...
Thank you for your help peeps
Hi mate, pop up the lights, remove the two or three screws holding the plastic surround in. (thats a bit awkward to get out ) Then behind that you should see some more screws that remove the whole headlight unit. Remove the bulb from the back.
Some of the early cars have sealed beam units so you might end up replacing the whole headlamp ( a ealed beam unit is like a giant bulb)
