Yaris 1.0Tr 2008 Replace Spark Plugs
Rascal Man
I own a 2008 1.0TR yaris
Does anyone know at what mileage/service interval its is recommended that you should replace the spark plugs?
I would appreciate any help regarding this
Many thanks
Rascal Man
Spark plugs should be replaced at 40,000 miles or 4 years. whichever comes sooner. Also engine oil, oil filter, air filter, pollen filter and brake fluid .
Thanks Lorna,
Can any you recommend which plugs to use, and what the gap is?
Thanks again
Rascal
Sorry, no idea about which spark plugs to use. I get mine serviced at Toyota, so its just whatever they use. No DIY for me ;)
No worries
With fuurther research i found NGK LFR6C-11 should do the trick.
I'd say have a look at those things in Halfords which say what ones are best but I found four years ago that they had the wrong sizes for the wipers. Seemed spot-on when I got a set of Bosch 'plugs for my old Starlet back in 2005 though. I've heard good things about NGK spark plugs, they'll probably outlive the car!
As with Lorna2, these days I let the garage do the work although once I found a bolt missing that holds the spark plug wiring down near the dipstick . .
