Indicator Cover
roger_37
Hello Members. My front passenger wing mirror indicator lens has cracked,
does anyone know can this be replaced without replacing the whole indicator cover.
Its a 2011 rav4 with indicators on the wing mirror, its the little clear plastic piece that
covers the flasher unit, any help would be appreciated thank you.
any help guy,s ?
Have you disassembled it (I haven't on mine) to look? Instructions attached. Step 6 should do it, I would think.
From this, it looks to me like it is all one piece, but I will try to remember to check for you later, whether the indicator lens has a separate part number.
MirrorRemoval.pdf
MirrorRemoval.pdf
thanks schm,not disassembled yet, on googling it seems like it is a seperate led light unit,but im not sure, ty for the information.
Yep, you're right and possibly in "luck"
Part number LHS is 81740-52031, RHS is 81730-52071, but check with Kingo or your dealer as sometimes the part numbers get superseded.
thanks shcm your a gent.
