Tansfer Box Leak ?
rambler
Hi all
Just had a crawl under Rav for curiosity....found this ( if pic's appear below,as not very good at this ).
Just had 110'000 mile service done,engine oil,oil filter, cabin filter...( now at 112'000 miles )
Don't think they needed to touch transfer box oil......but why would this happen .......now ?
If the seal around the filling plug has gone....why now ?
There is a drip just hanging off of the fins underneath.....anything to worry about ?
That is coming from the plug Jamie. Nip it up a bit. You need a 15/16" AF or 24mm socket.
It should have a special washer with a little rubber insert. Make sure you can see that first. If not Kingo will send you one.
