hi all hope you are all having a nice easter break. MY 1993 estima oil warning light
has come on even though my oil level (when cold) is ok. it seems to be making a
funny sound as well. different from normal. i have just had a cam belt change on it
and a service. i have just parked it to be on the safe side. looking through the
handbook it says some thing about oil pressure. temperature gauge is ok
can anyone help please.
just had my oil pressure check and i was told there is no pressure. what does this mean
New oil pump. slim chance of a blockage but prob the pump. the funny sound is prob the lack of oil getting to parts of the engine. i have no idea how much they are but the person who tested your pressure should have told you that its the pump and if it was a mechanic i would be really questioning how much he knows bout engines. hope its not to $$$ for you.
Im just curious of my panel. My Oil Change lights are on what does this mean? I just had an oil change? Could it be grounded? Thanks
Found the solution for this problem. I took of the black rubber cover from the front console (Speedometer) then insert a stick to press a toggle switch inside. Lights will now disappear.
