Radio - Sat / Nav Won't Switch Off Or Adjust
goho51
Hi again,
Has anyone experienced the satnav and radio just not reponding to any adjustments and not switching off when you exit the car? Had the radio on and everything just froze... thinking about taking out the fuse but wonder if there is a reboot or something that can be done?
Appreciate any help!
Gordon
Not experienced that.
Yes, pulling the fuse may help BUT, the B9004 needs a DVD in its drive when the power is restored. At first power up, it boots off the Map DVD (there is firmware on there as well as maps).
Otherwise, it will just sit there asking for the disk. You will get no functions at all (not even radio).
Point taken, I may have to though, it just won't switch off.
Pulled the fuse and re-inserted it, so far so good and the satnav seems to be working as well... fingers crossed.
