Tinting Rears
Jaco byte
Hello, thinking of tinting my rear lights and been looking about on various threads and seen that the best option is to use a product called Lamin-x like window tint film, then there's others have used spray like E-TECH to do it, which is best to use and also i bothered about when it comes to Mot time about it passing ok and at night time others not running into me because they don't notice me brakeing, could i also be pulled by the police as well ?
Any help/info would be appreciated thanks, Mike. :driving:
as for the MOT bit, may be a bit dodge if you do the full amont of coats in the video, i just did 2 LIGHT coats of nite shade (done by holding the can further away) and passed the MOT.
ok, thanks, did you remove your rears to tint them or just tape up around them on the vehicle ?, if you removed them was that easy to do.
Completely removed then lights off the car lol, this way u can do a better job on the lights. Easy to remove? Well just a few screws here and there and will come straight off
:hang:
Okey dokey excellent, thanks again for advice, taken on board. :thumbsup:
