Oil Change
Dave Evans
hi again all can someone please remind me the oil capicity for the t2 1.8 petrol due for an oil change did write it down but cant find it anywhere 3.7 litres comes to mind but that dosent sound enough thanks in advance
Go onto eurocarparts.com and type your reg into the search box, go onto oils and lubricants and then part details and it will tell you the capacity there, hope this helps,
Phil
spot on again for this forum job done and dusted about 20 quid in total that included buying an oil filter socket after spending an hour trying to get it off by hand also did cabin filter didnt know it was there until reading this supurb forum thanks again for all the great advice saving me and others a fortune in these lean times
