How To Remove Headlights Off My Yaris?
Rupesh17
Hi guys!!
Just ordered new bulbs and want to put them in myself into the headlights rather then paying someone and charging me silly amount to fit it in for me!
Anyone know how i can do this, i own a 54 plate Yaris
Cheers guys! :flowers:
You can remove the bulbs and replace them without removing the headlamps. Start on the easy one: driver's side first.
On the passenger side you are likely to drop the bulb as space is limited so some newspaper stuck in the gap under the headlamp prevents the bulb being lost in the undertray/broken on the ground when you do drop it. (which is highly likely: I did)
Space is very restricted when changing headlamp bulbs.....Be prepared to snag your knuckles
Also be very careful not to touch the glass of the bulbs with your fingers as this can cause the early failure due to contamination of the glass
Hi guys!!
The owners manual shows you how to change the bulbs and like others have said it can be quite a fiddly job, but being honest if you're having to ask this question then you'll wish you'd paid someone to fit them in the first place.
Wicked Cheers for the info lads, i changed both the bulbs but took me a while lol. Ultra White LEDs now are lighting up the whole road!
Be sure that the Ultra White LED headlights do not get you into trouble with the law or at MOT time as they are not strictly legal for on road use
