Lowering Springs Vvti Please Help :-(
dubstar81
I am after a few bits and finding it really hard to find 50mm or 60mm lowering springs.
Can anyone point me in the right direction?
Thanks in advance
Rich
I don't think T.O.C. is that sort of Club.
You need a "barryboys" type of forum, such as celica-club.co.uk or newcelica
Never seen any that drop as low as 50-60 between 30-40 is about your limit.Try eBay for a set of APEX ones or if your pockets are deep enough a set of EIBACHS should do the trick
You will not get lowering springs as low as 50-60mm for the Celica Gen 7. For this amount of drop you need to fit coilovers. Most lowering springs for this model are 30-35 mm drop over OM.
Try some of the more advanced Celica Forums for more on this.
