T180 Pick Up From Low Rpm
Shaun Clayforth
Hi
Recently bought an Avensis 2.2 T180 on a 56 plate
i have noticed there seems to be a problem when trying to accelerate from low rpm , say between 1000 / 1500 rpm
if i keep revs high or drop down a gear it picks up ok , i would expect car to pull away easily in 2nd or 3rd gear at low revs
any advice would be appreciated
regards
shaun
hello
what is total miles covered since yr last service?
by the way -- what works have been done?
however i am inclined you to check with EGR -- what is inside
regards/Igor
An EGR check would be a good start, but the turbo does not spool up til just below 1500 revs so you do tend to feel a surge in power over 1500, people often complain of a lack of power below 1500 on the T180 models
Kingo :thumbsup:
THANKS FOR THE REPLIES
tonite i have stripped the the egr valve and couldnt believe the crap in there .. cleaned it all all out (thanks to the chap who put the info n pics on here ) gonna fill up with diesel in the morning and add some fuel additive and then give it a blast down the m62 ..
lets hope its done the trick
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
