Sucking Air
tierney2td2
I have a 00 Toyota Avensis 2.0 TD GS, I recently changed the rockercover gasket but now when i am driveing it sounds like the car is sucking air at the front passengers side I cant hear it when i am sitting and just reving the engine, anyone any ideas what this could be thank you.
have you connected small dia rubber hose to the cover?
this hose is for ventilation purposes and must be connected to the turbo intake manifold or so
regards / Igor
I have eveything connected back the way it was, was talking to a guy how said it could be the A/C needing filled with gas could that be the problem
the A/C is close system
check with all rubber hoses -- it looks somewhere is hole or fitting lose.
regards
