Noisy Clutch?
Rupesh17
Hi Guys,
I think ive got a problem, just wondering what you guys think...Every time i push my clutch down it makes this rather squeeky noise, like when you rub 2 balloons together? This happens on my brothers Corolla T Sport as well, any ideas what this might be?
Maybe lack of lubricant?
Cheers Rupesh17
IIRC this is a semi-common problem on some Yarisusususes...
Can't remember the exact details - You'd be better off doing a search TBH - but from what I remember it's the pedal itself that's making the squeaking noise where it rubs against something in the footwell? Some grease in the right place should deal with it.
Hi Guys,
Cheers Rupesh17
You need to isolate the source of the noise. If it is the brake pedal then as Cyker suggests grease it. If it is the clutch slave cylinder then the pushrod arm needs greasing. Rubber grease in the cylinder end, do not use any other type as it will react with the clutch fluid, and white grease where it contacts the clutch release arm.
Regards Geoff Peace.
if its a quiet noise it may be the pedal linkage, if its loud then its the clutch release bearing.
For the greasing its not a case of reacting with the fluid - the cylinder is sealed so contact is not an issue, its more an issue that incorrect grease may effect the seals and cause them to swell or break down.
