Toyota Auris Rear Lights Wires Amperage
Gibergeist
Hi guys,
I'm trying to fit a towbar electric set to my Auris (2007 model), but I need to extend some of the wires from one side of the rear lights to the other side.
Does anyone knows which wire amperage should I use?
thanks
Purchase a tow bar wiring kit, this generaly comes with a per-wired 7 pin socket and all the necessary instructions to wire into the vehicle. Depending on what you want to power you may also require a 7 pin s (suplimentory socket) to power friidge etc when on the move.
