Wing Mirror
DRC58
Hi All
Just had wing mirror taken off and got a patern make to replace.
One problem, the new mirror is a heated type with 5 wires into the connector, Red, Brown, Purple and 2 Black. The connector in the car only has 4 wires, Red, White and 2 Grey.
Does anyone know which of the 5 goes wires goes with which of the 4 to power the mirror.
Any help will be gratefully received.
Cheers
DRC58
Welcome to TOC
From your Avatar can we assume the mirror is for a Corolla?
If that is the case you should ask your question in the Corolla Forum as this forum is for introductions only and not to ask tech questions
