Sudden Non Start With A 2000 Plate 1.8 Vvti Avensis
spannerchuck
My neighbors normally trusty avensis as sudden turned in to a non starter.
I haven't had much time to look at it,but there is no spark from all 4 coil packs,and no signal getting to to the fuel injectors.
Fuel pressure is fine,seems the ecu isn't receiving a signal from a particular sensor,or the ecu itself as packed up,no fault codes.
Just wondering if somebody else as come across this problem and might be able to shed some l light on it
cheers
Ian
If f.i. the cranckshaft position sensor is broken, the ECU "thinks" that the engine isn't turning and therefore doesn't inject or spark.
Just a thought....
The car wasn't as snappy on starting prior to this,so maybe clutch dust or its just knackered,do you have any tests to run on it?
cheers
