Gearbox Oil Change
Phil24RN
Hi everyone,
I have a avensis 2.0 D-4-D (09) estate tourer,
I am looking to change my transmission fluid, can anybody tell me the locations of the drain plug and filler point??
Regards Phil
HI Phil,unless you done a real great miliage and the oil is at the correct level there is no real need to change it the car gets normal use for a manuel box.
the drain plug will be at the the bottom of the box and the level plug will be on the side should not be hard to find.
If you do a search there may well be some pics someone has posted. Good luck.
