New And Need Advice
shead
hi all
just had cluch replaced on my Rav4, and i have noticed a leak, it seams to be comming from a small hole just above the the transmission fluid drin bolt, is this hole ment to be open or should it have a plug in it.
also abs light is on on dash after the cluch replacement how can this be fixed
thanks for your help
Hi and welcome. post your questions on the RAV4 club forum on here. there are very knowlegable memberes on there who will be pleased to advise you Good luck.
