Desperatly Need Parts Due To Mot Failure
o/sr tail light cluster and wiring harness.
cant believe how hard it is to locate these
need both before wednesday mornign
eBay has some possibilities
e.g. http://www.ebay.co.u...eaking&_sacat=0
or as you are in a rush, I guess the best bet would be to phone around the local breakers yards.
Whats the problem - physically broken (e.g. smashed)? In this case you can sometimes you can get away with fixing coloured plastic over the lens as an emergency repair.
If it's electrical, then there is very little that can go wrong with it - possibly terminals corrosion that could be cleaned up?
