Auris Spark Plugs
darrencairns
i wanted to change my sparks in my 2009 1.33vvt ive taken out the coil pack for the sparks but cannot remove the plug it looks like it has a metal sleeve inside any ideas ?
Just take the plug out as you would normally.
Socket size is quite tight (12mm socket maybe from memory).
Also easier with two short extensions rather than one long one I reckon.
