Engine Starts Then Stops Immediately And Management Light Comes On
I have a 2005 2.2 D-4D Corolla Verso - not missed a beat in the 5 years we have had it. Went out for a meal the other week, back to the car and pressed start - only a couple of lights on the dash flickered followed by a relay clicking sound from under the bonnet. Trouble getting the ignition to turn itself off to get the keyfob out so guessed that the Battery must be flat as.
Nothing left on to suggest why Battery would be dead so got friend to bring jump leads - left his truck running with leads on my Battery for 20mins - pressed start, all lights on dash all came on but relay only clicking again. Towed to bump start and fired up - all ok. Got a mile down the road and lights flickered and whole car died and then picked up again as I was pulling over, so carried on 100 yrds and this time it died completely. Assumed battery must be now faulty and not taking any charge. Towed it home (in 3rd gear so could use the brake/steering servo as on a short rope!) - never went above 30 on tow home.
Put new battery on the next day and pressed start - engine fired up and then cut out straight away with engine management light on.
Local Diesel centre has now had it for 2 weeks - computer told them it was wrong voltage to injector 3 & 4 so needed new injector management control unit (£495+fitting)... no start. Suggested that I could have made the timing belt jump by towing (scaring the life out of me) but they then checked this and all ok. They then had it looked at by a Toyota technician who suggested it was the starter motor as they have had too many of these go recently (£200+ +fitting) - It now starts but then stops immediately.. Full circle and back to where we started... Any ideas?
Firstly,welcome to the club
I think it would probably help anyone supply solutions if you have any fault codes to add.
All the best with this
Del
well i can tell you it wont make the timing belt jump as it dont have one! secondly its not the best idea to tow while in gear which makes things run when it shouldnt, do you get any smoke while trying to start, i think you ve had a direct short somewhere discharging the Battery which could point to many places let us know how you get on
Just had a thought, I'm not 100% but I believe the new ECU that was fitted may need coding into the vehicles immobiliser, the symptoms of cutting off just after starting sounds like the immobiliser cutting fuel because the new ECU is not correctly coded in.
Have you checked all the fuses that they're ok? Sounds like you have a short to ground somewhere. Check your wiring harnesses under the bonnet.
