Big Brakes
toy master
Does anyone know the biggest brake combination that will bolt up to the factory location of a kp61 starlet? (front) :eek:
  • 4 years later...
unfortunatly there is no direct bolt on replacement ...
I am running some 280ml vented u13 bluebird rotors on mine as they are already 4x 114.3 stud. All that is required to fit them is to machine the outside face of the starlet hub and they slide right on ... then i just made up a spacer plate to mount some sw20 MR2 calipers to ... on my personal site you can see the photos that may help others. you will need longer studs but these are readily available from the landcruisers.
just click my sig for the link
Q
p.s .... alot of people do complete strut swaps from cressida or ae86 series with spacers to fit the lower arms ... heaps of information can be found on both club-k.co.nz and kp61.net
