Can You Use The T180 Suspension?
brainii
I got a 1.4 petrol auris manual 2007 model.
1) Is it possible to install the T180 suspension on this or any other way to reduce roll in corners?
2) Also is there any way to increase performance?
The t180 suspension uses a fully independent double wishbone rear suspension as opposed to the rear torsion beam setup you currently have. No idea if it's possible to retro fit but I don't imagine it being cheap! You could buy some lowering springs from Eibach they may help.
As Phil states, it is totally unique to the T180/SR180 as it has totally different rear mounts.
Doubt if it is at all possible to retrofit as different rear memebrs are fitted in the weld shop to accomodate the mounts
