Dogs And Keyless Entry
fatgazzer
Hello
my wife has just changed the car from a mr2 to Rav4 question being haw do I lock the car without setting the alarm when the dogs are in it preferably with the windows open a bit. Its a 2009 XTR I know it says in the owners manual but thats in Stoke and I'm in Cornwall Doh!
thanks Gaz
Thanks Mystic tried that unfortunately it didn't work, good news is everyone on the campsite saw me waving my arms in the car :}
Gaz
Oh, well im sorry. That usually does it! Good luck finding out, im sure someone here will know what to do
As dogs don't have pockets I'd have though keyless entry was perfect for them.................
But they keep letting themselves out!!!
As you get out press the button by the front roof light, that turns off the sensors, then just lock the doors normally.
Gus
Edit: not the light switch, just the button near the light :-)
As you get out press the button by the front roof light, that turns of the sensors, then just lock the doors normally.
Gus
You'll know if it's worked 'cos the LED repeater by the heater controls will flash quickly.
That'll be he button that says OFF with a picture of a sensor?
Thanks Gus that seemed to do the trick
Gaz
