Celica Gs3e
MRTOOLS
hi all i have a 87 2000gt with a gs3e the car as been running brill until a few days a go, i can't get the revs down it is reving at about 25000 revs any ideas on this matter.
many thanks
*****MRTOOLS***** :crybaby:
its not auto jimma its a manual box.
thanks any way jimma for your help
*****MRTOOLS*****
u mean the air intake temp sensor actually has a use? I've left it off before and only noticed the next time i've popped the bonnet to check the oil etc... Wouldn't have thought it'd have that much effect.
I thought that Pete3S-FE but it looks like it as its uses . i said it is runnig a treat but after a good run noticed it is not 100% (lack of power on top end )looks more like the ecu not working very well i got a spear one to try i will just see if its that it.
*****MRTOOLS***** <_<
Jus an idea but when was the timing belt last done? someones pointed out to me that they can be lax when the belt gets to a certain age, I know it isn't an easy job to do (mine was done three weeks ago :S) but it can affect the way it runs.
Mines an 88 and i'm sure there's numerous things wrong with it, apart from replace everything i'm a little stuffed. Sometimes it'll feel really strong and sometimes it'll be hesitent etc... b00dy thing.
Oh well good luck with ure troubles.
hi Pete3S-FE my timing belt was only done about 3 months ago but will have a look to see if its slack, also going to check spark plugs and air filter because can't remenber last time they was done .
*****MRTOOLS*****
