2008 Avensis Extreme Vibration, Lack Of Power
gibbonsd
I HAVE A 2008 AVENSIS D4D WHICH HAS COVERED 200000 MILES. IT HAS DEVELOPED A EXTREME VIBRATION AND LACK OF POWER. THERE ARE NO MIL LIGHTS COMING ON. I HAVE REPLACE FLYWHEEL, STEP 2 INJECTORS WITH ECU UDATE, WHEELS BALANCED, EGR CLEANED, MANIFOLD STRIPPED AND CLEANED. I AM NOW RUNNING OUT OF
A) CASH
B) IDEAS
C ) THE WILL TO LIVE.
DOES ANYBODY HAVE ANY SUGGESTIONS. THANKS IN ADVANCED
it looks like SCV play with you, subject the above statement is true
besides - please explain in details what has been done with INJECTORS
check with fuel filter water drain as well (thru bottom valve)
regards / Igor
Thanks for your reply. The injectors have been replaced with new denso injectors from Toyota . They tell me that these have been modified. I have a it2 tester which I have done an Ecu update to the newest software available.
ok
EXTREME VIBRATION AND LACK OF POWER - may be resulted by:
- lack of control signal on the onjector control solenoid;
- fault of the rail pressure sensor;
- SCV play due to colenoid issue;
- water in the diesel;
- air in the suction lines;
- voltage supply failre;
- MAF sensor is dirty;
- overfueling due to poor injection;
- cat converter blocking by carbon;
- fuel pump delivery valve failure;
- booster pump in the tank failure
etc
regards / Igor
