98 Toyota Avensis 1.8Gs
andrewm1
Hi i can feel a vibration through the engine when the revs are coasting down at around 25.000/30.000 it does this when stationary or driving and going through the gears
its a 98 toyota avensis 1.8GS
check with MAF sensor and clean it.
regards
regards
Thanks would this be connected to the air box by any chance ?? i have looked in the haynes book but there is not much info on it
check with an engine air filter housingor plastic hose between throttle and air filter housing --- you will see a flange connected MAF
regards
