Hatchback Rear Window Seal
sproutdreamer
Hi
The plastic seal/trim around the glass on the lifting hatch seams to have shrunk and pulled away from following the rounded corner of the bottom of the glass housing. Although it does not seem to be leaking yet I am wondering if this was a big or difficult job to replace this myself.
I am not sure whether this is just an outer trim and the rear boot window is stuck in or whether this is the actual window rubber that the window is seated in but I am loath to start to investigate until I am ready to repair it!
Haynes type manuals say very little about this so any information about the window and seal would be very helpful.
