Hi, I got a Verso 2007 automatic, and was told I need to replace the clutch in the car. In the Toyota garage I got a quote over £2000 for this to be done. I was told there is no other place where this can be replaced, I just want to find out if this is correct.
Thanks for any replies...
  • 2 months later...
Hi I have a similar problem and the gargar says it will cost £1500 !! its a 54 reg so i am not sure if its coverd by the recall?
Garage says the clutch and the control unit has to be changed is this correct?
any advice ot help i would be grateful
thank you!
