Have been asked by a mate to pass this on:
APEX PERFORMANCE are doing a group buy on AVCR's, and need about 20 peeps min to do it, as they are buying a huge box load from the US i believe.
Cost will be £269 a throw.
Apex performance (Bren) are a good place usually very cheap and delivery like a speeding bullet from my previous experience of them B)
Have a look here:
CLICKY
PLEASE DONT ASK ME ANYTHING ABOUT IT COS I DONT KNOW, JUST PASSING THE MESSAGE! Contact Bren at apex.
APEX PERFORMANCE
cheers B)
My name is down .. just need the rest of the Apexi line now :)
:thumbsup: if i had a turbo id be on the list...... maybe ill get one anyway cos they look B) :lol:
Anyone got one of these and know how to set it up proper?
what does it do ?
Electronically controlls boost.
but my unichip does that
Ah yes, but you can't adjust the boost in real time or program a specific level of boost for a given number of revs or program your boost levels based on speed etc. Read the following for all the info you'll need:
http://www.apexi-usa.com/electronics_savcr.asp
I'm suprised you didn't find the link yourself, you can get to it through the inital post in this thread.
don't worry Jim your unichips better, anyone whos going to buy them an experience mapper?
Oh, yeah, should have added that you need to have mapping experience to get the best of out it, in fact it's probably essential.
yeah .. but the being able to re-map on the fly will be handy .. I can't be ****d getting a full re-map of an ECU I wanna play with 17psi for an afternoon ..
Probably best to steer old Jim clear of this one.... boom.....
Just arrived ..
respek my bad self .. he he ..
shamone ..
(It's fairly bling .. )
Just arrived ..
shamone ..
Sweeeeeet B)
The AVCR was like the holy grail when i had my sx :) never did get one :(
Hope it works ok, some say they are simple as to set up others go cross eyed :D
I think it's a case of tapping into the loom for my RSM and then adding the solenoid and the pressure sensor ..
smiffad don't u have an n/a...?
hows the APEXi gonna help u there, i thawt it controls boost
note: i'm too lazy to read up on it
-Z
Bibbs - fitting its easy, tis the degree you need to understand the menus thats fiddly :D
ZeroBlade - i do i was joking ;)
:) - so all I need is the pressure sensor tapped into the same hose as my boost guage .. and the Solenoid replaces my G-valve ..
I've got a task for the weekend now !!
FITTED !!! and it's working/flashing stuff :)
Now gotta bolt the car back together .. half way thought and I find out I didn't have a trrottle sensor for the RSM and I need to get a feed from the ECU to the dash .. again .. for the third time ..
I've now got an FCD, WI, RSM & AVC-R all spliced into my loom, looks more like a web made by a spider on acid ..
well, after spending £50 on stuff to fit it, and giving myself a massive shiner on my finger by picking up the soldering iron by the hot end .. I'm quite chuffed to say it works :)
All my own work too ..
so i take it this gb is no more then? bl88dy typical, innit?! :rolleyes:
Call them .. I KNOW they had a few spare ..
Tell 'em "Ben Bibbings from Toyota Owners Club" sent ya ..
cheers bibbs. will phone them asap :D
Think its a relatively long running thing..... even if it ent sure Bren will manage to sort something for you, he's good like that :thumbsup:
Glad your chuffed with yours bibbs, must be a time of the year thing, i managed to pick up my soldering iron by the wrong ent twice this weekend as well :wacko: luckaly swift reactions left me with no injuries.... :hokus-pokus:
