Fuse Box Location On Gen 5 ! Help !
mahatcha
HELP !!
I have just recentally bought a gen 5 pop up light model jap import - and have had both my indicatiors/hazzords fail !
I need to get it sorted before I drive home from work - but cant locate the fuse box!
I though it would be under the steering coloum but cant find it :(
Can someone please put me out of my misery and point me as to where I should be looking ! :!Removed!:
Thanks guys
:thumbsup:
There are the two main fuse boxes located under the bonnet - the one adjacent to your Battery houses the 15amp fuse for the hazzards and horn,
There is also another box next to your accelerator pedal which conatins a 10 amp fuse for the indciators themselves -
Check them out
:thumbsup:
there are 3 fuse boxes in total, 2 under the bonnet and the 3rd is the one you need, it should be located next to the accelerater, on the right of the footwell. its quite high up, so you'll need to get right into the car. it should have a small black square cover on it. take the cover off, and on the reverse it'll tell you what the fuses are for. I can't remember which 1 is for the indicators off hand.
